ruddle38
#1 Posted : Wednesday, July 14, 2010 5:55:24 AM(UTC)
ruddle38
My washer when placed on super load compacity it overflows. When I placed the washer on "small load" the water level stopped at the large compacity even though it was set on small Load. Also, the washer will agitate but it will not spin nor will it rinse. It just hums as if it is going through the spin and rinse cycles. Can anyone help me?
sidfink43
#2 Posted : Thursday, July 15, 2010 4:47:03 PM(UTC)
sidfink43
Sounds like you hae multiple problems, but lets fix the water level thing first.
Check the tube going from the water level switch to the tub, and clean it out thoroughly. If this does not fix things, try replacing the water level switch, this part here.
Part number: AP2045906
See how things work now.
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
GE Washer Wont Spin or Agitate (Washer Repair)
by rangerjoey76 12/8/2013 11:55:34 AM(UTC)
GE washer wont spin (Washer Repair)
by btv268 12/8/2012 6:43:14 PM(UTC)
ge washer wont spin (Washer Repair)
by malcolm12 6/8/2012 10:04:15 AM(UTC)
by rich bean 3/21/2012 10:25:32 AM(UTC)
by briwill99 12/29/2011 10:42:36 AM(UTC)
by blizzzz 10/5/2011 6:11:31 PM(UTC)
by memin 3/28/2011 9:41:11 AM(UTC)
ge washer wont spin in rinse (Washer Repair)
by crownjason 3/9/2011 7:24:03 AM(UTC)
GE Washer wont spin (Washer Repair)
by Wedge 73 11/26/2009 3:50:55 AM(UTC)
GE washer wont spin belt appears loose (Washer Repair)
by parkman009 6/17/2008 8:43:16 PM(UTC)
