rich bean
#1 Posted : Wednesday, March 21, 2012 10:25:32 AM(UTC)
rich bean
My top load GE washer model whse5240d1ww runs fine including draining but will not spin to get the water off the clothes. It has a magnetic saftey switch on the lid. I am not sure how to bypass to check the switch to see if thats the problem.
Thanks Rich
Joe / APP Team
#2 Posted : Thursday, March 22, 2012 1:32:18 PM(UTC)
Joe / APP Team
Rich,
Without a model number it will be rough, but, Check and make sure the magnet is still mounted to the lid. you'll need to remove the top of the washer so you can access the switch wiring, usually they are orange and white, and the connector is located in the left rear corner of the cabinet.
Another check, while you're in the area, would be the water level switch and tube, the switch has to reset to the "empty" setting, or the washer won't spin, you can disconnect the hose, and see if the washer spins, if so, blow in the tube and clear any build up or debris in the hose.
Thanks,
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
GE Washer Wont Spin or Agitate (Washer Repair)
by rangerjoey76 12/8/2013 11:55:34 AM(UTC)
GE washer wont spin (Washer Repair)
by btv268 12/8/2012 6:43:14 PM(UTC)
ge washer wont spin (Washer Repair)
by malcolm12 6/8/2012 10:04:15 AM(UTC)
by briwill99 12/29/2011 10:42:36 AM(UTC)
by blizzzz 10/5/2011 6:11:31 PM(UTC)
by memin 3/28/2011 9:41:11 AM(UTC)
ge washer wont spin in rinse (Washer Repair)
by crownjason 3/9/2011 7:24:03 AM(UTC)
GE Washer wont spin (Washer Repair)
by ruddle38 7/14/2010 5:55:24 AM(UTC)
by Wedge 73 11/26/2009 3:50:55 AM(UTC)
GE washer wont spin belt appears loose (Washer Repair)
by parkman009 6/17/2008 8:43:16 PM(UTC)
