My washer when placed on super load compacity it overflows. When I placed the washer on "small load" the water level stopped at the large compacity even though it was set on small Load. Also, the washer will agitate but it will not spin nor will it rinse. It just hums as if it is going through the spin and rinse cycles. Can anyone help me?
Sounds like you hae multiple problems, but lets fix the water level thing first. Check the tube going from the water level switch to the tub, and clean it out thoroughly. If this does not fix things, try replacing the water level switch, this part here. Part number: AP2045906
See how things work now.
