Kevin Goad
#1 Posted : 15 years ago
Kevin Goad
I opened the transmission case and lost most of the oil. I now know that it is the direct drive coupling causing my washer not to agitate or spin. I can put it back together but any recomendations on what kind of oil I can put in it. I have light gear oil that I use in speed reducers at my work. Can I use this?
#2 Posted : 15 years ago
The gear case oil made by Whirlpool Part number: AP3072960
The motor coupling Part number: AP3963893
Kevin Goad
#3 Posted : 15 years ago
Kevin Goad
Thanks Gene. I got what I needed locally, should reassemble tonight and end my wife's trips to the laundramat
thanks again
Kevin
Transmission Oil Type (Washer Repair)
by RdPope01 9 years ago
GE Profile transmission Oil leak (Washer Repair)
by MilwMonstr 10 years ago
Transmission Oil Level (Washer Repair)
by rbarrys 12 years ago
transmission oil (Washer Repair)
by boniray 14 years ago
transmission oil for washer? (Washer Repair)
by jen58 17 years ago
Transmission Oil Fill ? (Washer Repair)
by DaveSAAB 17 years ago
Transmission Oil (Washer Repair)
by toddpole 18 years ago
