Kevin Goad
#1 Posted : Wednesday, July 7, 2010 9:52:21 AM(UTC)
Kevin Goad
I opened the transmission case and lost most of the oil. I now know that it is the direct drive coupling causing my washer not to agitate or spin. I can put it back together but any recomendations on what kind of oil I can put in it. I have light gear oil that I use in speed reducers at my work. Can I use this?
#2 Posted : Wednesday, July 7, 2010 4:27:53 PM(UTC)
The gear case oil made by Whirlpool Part number: AP3072960
The motor coupling Part number: AP3963893
Kevin Goad
#3 Posted : Thursday, July 8, 2010 3:51:05 AM(UTC)
Kevin Goad
Thanks Gene. I got what I needed locally, should reassemble tonight and end my wife's trips to the laundramat
thanks again
Kevin
Transmission Oil Type (Washer Repair)
by RdPope01 7/13/2016 5:43:30 AM(UTC)
GE Profile transmission Oil leak (Washer Repair)
by MilwMonstr 11/17/2014 6:39:43 AM(UTC)
Transmission Oil Level (Washer Repair)
by rbarrys 4/6/2013 7:46:37 AM(UTC)
transmission oil (Washer Repair)
by boniray 9/1/2011 10:34:30 PM(UTC)
transmission oil for washer? (Washer Repair)
by jen58 4/7/2008 3:34:49 PM(UTC)
Transmission Oil Fill ? (Washer Repair)
by DaveSAAB 1/28/2008 5:46:43 AM(UTC)
Transmission Oil (Washer Repair)
by toddpole 7/24/2007 6:52:24 PM(UTC)
