toddpole
#1 Posted : Tuesday, July 24, 2007 6:52:24 PM(UTC)
toddpole
What is an appropriate oil to replace whirlpool transmission oil? I found the plastic gear shredded inside the transmission and the oil is ten years old as well, probably time to replace it. :D
#2 Posted : Tuesday, July 24, 2007 9:38:51 PM(UTC)
toddpole
The part number for the Whirlpool transmission oil is AP3072960
For the future references following is the break down diagram for the Whirlpool washer Model LXR7144EQ1
Good luck.
Transmission Oil Type (Washer Repair)
by RdPope01 7/13/2016 5:43:30 AM(UTC)
GE Profile transmission Oil leak (Washer Repair)
by MilwMonstr 11/17/2014 6:39:43 AM(UTC)
Transmission Oil Level (Washer Repair)
by rbarrys 4/6/2013 7:46:37 AM(UTC)
transmission oil (Washer Repair)
by boniray 9/1/2011 10:34:30 PM(UTC)
by Kevin Goad 7/7/2010 9:52:21 AM(UTC)
transmission oil for washer? (Washer Repair)
by jen58 4/7/2008 3:34:49 PM(UTC)
Transmission Oil Fill ? (Washer Repair)
by DaveSAAB 1/28/2008 5:46:43 AM(UTC)
