midsound
#1 Posted : Tuesday, June 22, 2010 8:10:37 PM(UTC)
midsound
When our Maytag dishwasher starts up it makes a grinding sound. I have removed the lower spray arm and the circular plastic cover over the chopper and couldn't find any debris in there. But also didn't know if I needed to go further. Also removed lower access panels to listen to noiseand it is emitting from around the motor.There's also an occassional humming sound that sounds similar to a solenoid valve functioning - but is a noise that we have never heard before. Any ideas or suggestions?
ivin
#2 Posted : Wednesday, June 23, 2010 6:52:57 AM(UTC)
ivin
Is the noise heard during startup or do you hear a grinding noise while operating and the spray arms are spraying?
The reason I ask is that I had a similar grinding (horrible) noise when the dishwasher was running and the problem turned out to be a loose spray arm in the middle - the one below the top basket. I secured the tube that supplies water to the spray arm to the upper rack with a plastic tie wrap and the problem went away!
Something you may want to try.
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
Whirlpool Direct Drive Top Loader, grinding noise on spin start (Washer Repair)
by GRTison 5/1/2022 4:14:53 AM(UTC)
Maytag washer mvwb300wq2 has low grinding noise and won't turn on (Washer Repair)
by mzimmerman72 4/4/2022 2:01:41 PM(UTC)
Whirlpool washer agitator working but with grinding noise (Washer Repair)
by Guest 9/23/2021 1:06:39 PM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
GE Profile Quiet Power 2 - grinding noise BETWEEN stages? (Dishwasher Repair)
by Guest 8/19/2021 1:53:26 PM(UTC)
Whirlpool washer started making grinding noise (Washer Repair)
by apples99 6/30/2021 3:29:01 PM(UTC)
Grinding noise when running. (Washer Repair)
by Donaldbain007 5/30/2021 1:13:54 PM(UTC)
Kenmore 80 series won’t spin making grinding noise and smells burnt (Washer Repair)
by Liciasmommy 5/29/2021 2:00:00 PM(UTC)
Whirlpool Cabrio MVWC400XW making horrible high pitched grinding noise (Washer Repair)
by kwale 3/6/2021 1:11:38 PM(UTC)
Maytag front-load grinding noise... (Washer Repair)
by freq_out 6/29/2020 9:58:07 PM(UTC)
Amana washer makes grinding noise when running (Washer Repair)
by Bruce Congioloso 5/14/2020 11:44:16 AM(UTC)
Kenmore Waser Grinding noise (Washer Repair)
by modsolution 2/14/2020 2:32:03 PM(UTC)
amana washer, grinding noise (Washer Repair)
by oilspotnm 8/11/2018 10:04:08 AM(UTC)
Grinding Noise at End of Spin Cycle (Duet Frontload) (Washer Repair)
by brianinseattle 4/11/2018 11:31:36 PM(UTC)
