#1 Posted : Saturday, June 19, 2010 11:54:15 AM(UTC)
Cannot find any info on this unit prhaps someone else will have more lick.
You said you changed the timer so I am assuming you have a mechanical defrost timer.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
by aarrington 2/25/2022 5:39:48 AM(UTC)
Ice maker icing up on the back side (Refrigerator & Freezer Repair)
by claimsinspect@gmail.com 4/26/2021 8:35:36 AM(UTC)
GE Profile Fridge Coil Icing Up (Refrigerator & Freezer Repair)
by srgould41 8/27/2018 6:53:49 AM(UTC)
Freezer coils icing up (Refrigerator & Freezer Repair)
by kay edman 8/7/2017 5:04:19 PM(UTC)
Fridge icing up internally and leaking onto the floor (Refrigerator & Freezer Repair)
by Raleighman 6/11/2014 12:53:03 PM(UTC)
by Kaidok 5/29/2014 1:00:04 PM(UTC)
Top freezer icing up after power outage (Refrigerator & Freezer Repair)
by Markgova 3/15/2014 6:50:08 AM(UTC)
Freezer icing up on coil sides (Refrigerator & Freezer Repair)
by nackster 2/19/2014 5:08:13 PM(UTC)
by tal041482 2/4/2013 3:48:33 PM(UTC)
Refrigerator Freezer icing up (Refrigerator & Freezer Repair)
by star95presson 10/14/2012 9:18:40 AM(UTC)
freezer condensor icing up (Refrigerator & Freezer Repair)
by bmbssa 9/22/2012 9:09:41 AM(UTC)
Maytag side by side freezer is icing up (Refrigerator & Freezer Repair)
by Measic 8/17/2012 11:46:29 AM(UTC)
Freezer Not Defrosting, ICING UP Model ED2FHEXSB02 (Refrigerator & Freezer Repair)
by Microman66 7/6/2012 8:10:36 PM(UTC)
by CapeCod53 6/21/2012 4:44:55 AM(UTC)
freezer icing up (Refrigerator & Freezer Repair)
by robbob41 6/19/2012 4:36:17 PM(UTC)
