My Dryer Won't Get Hot We Have Replaced The Thermal Cutoff And The Thermal Fuse But It Still Won't Get Hot. What Should We Do Now?
If any of these parts are open (no continuity) then it will not heat. If all of these are ok and you have 240 volts going in then the timer is most likely fried. SublimeMasterJW attached the following image(s):
