I have a gas dryer & just stopped getting hot ?? Was checking & should i get Cont from all 4 wires on the cycling thermostat I get it from top to bottom but not sise to side ??
If you don't have continuity between the larger terminals on the cycling thermostat, the part is bad. It's a good idea to replace all the thermostats together, since they're not expensive.
what I am asking about is next to the ex vent it has 4 wires going in to it ?? what should the coils on the gas valve ohme out to ??
