notsure
#1 Posted : Wednesday, September 5, 2007 10:48:47 AM(UTC)
notsure
Cold water continues to fill the machine without stopping. No problem with the hot water shutoff. Serious problem.
#2 Posted : Tuesday, September 11, 2007 2:06:20 AM(UTC)
If it still fills without power to washer=new water solenoid time.
danny.niver
#3 Posted : Tuesday, September 11, 2007 6:05:55 AM(UTC)
danny.niver
washer over fills, hot and cold water, Kenmore washer.
#4 Posted : Wednesday, September 12, 2007 1:50:16 AM(UTC)
If your washer is unplugged and water flow stops, you probably have a bad water level switch or a clogged sensor hose, probably due to soap residue at the bottom of the tub. Blow in the hose and clean out at the bottom.
notsure
#5 Posted : Wednesday, September 12, 2007 5:04:39 AM(UTC)
notsure
Thank you for your information. It was right on! Problem fixed. Thanks again.
