Cold water continues to fill the machine without stopping. No problem with the hot water shutoff. Serious problem.
If it still fills without power to washer=new water solenoid time.
washer over fills, hot and cold water, Kenmore washer.
If your washer is unplugged and water flow stops, you probably have a bad water level switch or a clogged sensor hose, probably due to soap residue at the bottom of the tub. Blow in the hose and clean out at the bottom.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) If it still fills without power to washer=new water solenoid time. Thank you for your information. It was right on! Problem fixed. Thanks again.
