Cold water continues to fill the machine without stopping. No problem with the hot water shutoff. Serious problem.
If it still fills without power to washer=new water solenoid time.
You have been a member since:: 9/11/2007(UTC) Posts: 2
washer over fills, hot and cold water, Kenmore washer.
If your washer is unplugged and water flow stops, you probably have a bad water level switch or a clogged sensor hose, probably due to soap residue at the bottom of the tub. Blow in the hose and clean out at the bottom.
Originally Posted by: richappy If it still fills without power to washer=new water solenoid time. Thank you for your information. It was right on! Problem fixed. Thanks again.
