Chris Jensen
#1 Posted : 16 years ago
Chris Jensen
My Heavy Duty Maytag Quiet Plus 6-cycle intellidry dryer makes a real loud noise when I turn it on and then it will operate for about 40 minutes before it dies. If I wait for a while, it will turn back on again with the same grinding noise as before and the same results. I can smell a faint smell of something possibly burning; perhaps, the motor is overheating. If the fix is not too complicated or expensive, I can buy the part and do it myself. Does anyone have any ideas as to what might be wrong with it? :confused:Thanks. CJ
#2 Posted : 16 years ago
Replacement parts for MAYTAG MDE9706AYW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16023086.pdf
Does sound like the drum is rubbing on something and overloading the motor causing it's thermal cut-off to trip. Run your fingers along the seals at the front and the back of the drum, perhaps something has become jammed in between the drum and the cabinet.
Could be a number of things, you will have to open it up and check it.
Before doing this try to locate the approximate location where the grinding is coming from, this should help find it.
At the top of my list would be the front glides.
Once opened up check all moving parts for wear and replace as necessary, might as well give it an overhaul while you have it open.
Give the interior a good clean and clean/check your vent system.
kayakcrzy
#3 Posted : 16 years ago
kayakcrzy
Chris turn the dryer on for a minute, and the shut it off. If the sounds is still herd for a few seconds after the dryer is shut off, that would mean the front blower wheeel is broken, and the reason the dryer motor is shutting down is because it is getting hot. That is common problem on that product. Take the front off, and check it. Let me know what you find. Tom ApplianceEducator.com
Gas Dryer cuts off after 5 mins (Dryer Repair)
by opeter 7 years ago
dryer cuts off (Dryer Repair)
by amchret8@aol.com 12 years ago
Dryer cuts off (Dryer Repair)
by roberson3714 13 years ago
Kenmore Electric Dryer cuts off after running 2/3 minutes (Dryer Repair)
by Robert Ferrell 13 years ago
Kenmore stack w/d dryer cuts off after 1 min. PLEASE ADVISE need as much feedback as (Dryer Repair)
by dhompe3 14 years ago
dryer cuts off after running for about 2 min (Dryer Repair)
by jim5sexton 14 years ago
Dryer cuts off then will turn back on after cooled off (Dryer Repair)
by hollywilhite 14 years ago
by Van Johnson 15 years ago
The Dryer cuts off (Dryer Repair)
by ineedheep 16 years ago
dryer cuts off after 10 minutes but will start (Dryer Repair)
by 30tredog 16 years ago
