libertyappl
#1 Posted : Friday, October 3, 2008 12:52:36 PM(UTC)
libertyappl
Check the thermostat inside the icemaker.
grangecam
#2 Posted : Sunday, October 5, 2008 9:36:57 AM(UTC)
grangecam
I am having a similar problem as Jake. However, I am getting a voltage reading from the plug inside the freezer wall. the voltage is only 65 volts.
this seems odd, since the icemaker has a sticker on it which says 115V AC 60hz. Is there a voltage regulator somewhere else in the fridge? Should the icemaker be getting 115 volts? The motor works fine when connected to 115volts AC directly.
dzieour@ranchomurieta.org
#3 Posted : Thursday, June 18, 2009 3:55:16 PM(UTC)
Originally Posted by: Jake Finch Go to Quoted Post
Can someone tell me where does the 115v come from that powers the icemaker plug on the right side of the icemaker. By that I mean where does the incoming power on the black w white strip and the white wires feed from (115v)? A terminal connection? A Wiring bundle with no fuses? Where does the 115v break off to the various devices in the whole refriderator?
Have you had a resolution yet?
#4 Posted : Monday, July 13, 2009 11:24:23 AM(UTC)
I had only 30vac when I check for power. Replaced ice maker and fix problem also.
dave
Kenmore Ice maker power line check (Refrigerator & Freezer Repair)
by Surfmob 6/25/2020 8:02:40 AM(UTC)
Kenmore Ice Maker (Refrigerator & Freezer Repair)
Belarus Charba 6/2/2016 7:10:02 AM(UTC)
Kenmore ice maker not producing (Refrigerator & Freezer Repair)
by rashillinger@hotmail.com 4/20/2016 9:23:18 AM(UTC)
Kenmore Ice Maker and Ice Door Not working (Refrigerator & Freezer Repair)
by Austex_Egger 2/15/2016 7:25:22 PM(UTC)
Kenmore ice maker won't dispense cubes (Refrigerator & Freezer Repair)
by patlocke 5/21/2014 9:13:21 AM(UTC)
Kenmore ice maker is not working (Refrigerator & Freezer Repair)
by jthreatt 3/4/2013 8:11:46 AM(UTC)
Kenmore ice maker leak, tried everything! (Refrigerator & Freezer Repair)
by Bgmwd 7/6/2012 6:35:14 PM(UTC)
Kenmore Ice Maker not making Ice (Refrigerator & Freezer Repair)
by ghauptman 5/25/2012 1:47:12 PM(UTC)
Kenmore ice maker not making ice (Refrigerator & Freezer Repair)
by rswareing 5/4/2012 8:49:05 AM(UTC)
Kenmore Ice Maker overflowing with water (Refrigerator & Freezer Repair)
by splumer 3/26/2012 5:33:13 AM(UTC)
Kenmore Ice maker - no water (Refrigerator & Freezer Repair)
by mbowman44 12/17/2011 3:47:12 PM(UTC)
Kenmore ice maker flap door will not auto close... (Refrigerator & Freezer Repair)
by Choski 2/19/2011 7:54:17 PM(UTC)
Kenmore ice maker not working (Refrigerator & Freezer Repair)
by jimajr 12/23/2010 7:29:56 PM(UTC)
Replace control board for whirlpool/kenmore ice maker (Refrigerator & Freezer Repair)
by molee@watanabenason.com 6/18/2010 10:24:00 AM(UTC)
by ldutton 5/1/2010 8:15:32 AM(UTC)
