ol bob
#1 Posted : 17 years ago
ol bob
water is working with the ice maker and filter but will not pressure up to the spigot in the door. i have pressure to the bottom of the door but it will not go on up through the line. it has done this several times in the last year. i can usually jiggle the line and it resumes working, but not this time. any suggestions?
TechnicianBrian
#2 Posted : 17 years ago
TechnicianBrian
If you can disconnect the line at the bottom of the door, actuate the dispenser lever and have water come out, then you water line inside the door is probably frozen. You can try heating the inside of the door with a hairdryer to thaw it and see if it starts working again. Sometimes the doors are made with the water line to close to the inner liner allowing cold air to freeze the remaining water after use. No good fix for it other than replacing the door.
Water dispenser not working GE Profile PSHs6TGXBDS (Refrigerator & Freezer Repair)
by klkaylor78 about a year ago
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 2 years ago
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 2 years ago
Kenmore Elite 795.72489.411 water dispenser not working (Refrigerator & Freezer Repair)
by fjfagergren 4 years ago
Water dispenser not working hums but no water. (Refrigerator & Freezer Repair)
by mouse51180 6 years ago
Water Dispenser not working but ice maker is still working (Refrigerator & Freezer Repair)
by Bobby-Houston 6 years ago
by tmeiss 9 years ago
Water dispenser not working, parts replaced (Refrigerator & Freezer Repair)
by pdog 10 years ago
GE Refrigerator water dispenser not working (Refrigerator & Freezer Repair)
by Jinxpalm 10 years ago
Water dispenser not working with filter. Works without filter (Refrigerator & Freezer Repair)
by kathut 11 years ago
by help810 11 years ago
LG Frig Ice & Water dispenser not working, No Light (Refrigerator & Freezer Repair)
by LG_Frig_Dispenser_Problem 11 years ago
Water dispenser not working. (Refrigerator & Freezer Repair)
by DVDA247365 11 years ago
produce drawer too cold; water dispenser not working (Refrigerator & Freezer Repair)
by houseofreg 12 years ago
water dispenser not working after actuator replacement (Refrigerator & Freezer Repair)
by rd27 12 years ago
