I have a GE Profile Refrigerator (Model: PSW23PSWCSS).
When we put a cup against the water dispenser lever I can hear something humming, but we do not get any water.
I replaced the filter in case there was a glog (and it was time to replace it). I also replaced the water solenoid. We are still not getting any water.
I disconnected the water line and checked the water source is still flowing.
I removed the water filter and pressed the lever with a cup in the inside of the fridge hoping that water would come out of the filter connection, but still nothing.
I hear a pump (maybe) that is trying to run, but am unsure if there is another pump I might need to replaced or where I should look for the issue next.
Any help is appreciated.. Thanks
Are you still making ice?
