Johnkut
#1 Posted : 17 years ago
Johnkut
How do I replace the defrost heater? Where is at? Please step by step instructions.
#2 Posted : 17 years ago
Are you sure the problem with your fridge is the bad defrost heater?
Johnkut
#3 Posted : 17 years ago
Johnkut
Yes. I paid a service man to come look at it. He said it was the Defrost timer and heater defrost.
#4 Posted : 17 years ago
You can find the complete instructions how to replace the defrost heater in the attached document.
- The part number for the defrost heater is AP2114859
- The part number for the defrost thermostat is AP2150024
- The part number for the defrost timer is AP2111929
- Here are the break down diagrams for the Frigidaire refrigerator Model FRS20ZRGD5
Good luck.
File Attachment(s):
How To Remove The Defrost Heater SxS.doc (26kb) downloaded 63 time(s).
Johnkut
#5 Posted : 17 years ago
Johnkut
When I bypass the defrost thermastat, the heater gets hot in manual defrost mode. Could it be just the t-stat
#6 Posted : 17 years ago
In that case there is nothing wrong with the defrost heater.
The problem is the defrost thermostat.
Johnkut
#7 Posted : 17 years ago
Johnkut
Thanks. They quoted me a price to change the heater of $450.00. Saved a bundle.
#8 Posted : 17 years ago
I'm glad to hear it.
Happy New year!
Johnkut
#9 Posted : 17 years ago
Johnkut
Oh, by the way, do I have to turn the dial on the timer again, or just let it where it is at?
#10 Posted : 17 years ago
Leave the timer on defrost. In about 30 minutes it should switch to cooling and you will hear the compressor is running. If it would not then replace the timer too.
SAMSUNG RF26J7500SR/AA - defrost heater testing (Refrigerator & Freezer Repair)
by curious99 2 years ago
defrost heater not working but testing fine on multimeter (Refrigerator & Freezer Repair)
by doland 2 years ago
Samsung Bottom Freezer Refrigerator Defrost Heater Replacement Part Help (Refrigerator & Freezer Repair)
by treefort 2 years ago
Replacing the defrost heater, one bulb or two bulb heater? (Refrigerator & Freezer Repair)
by emilclintoc 3 years ago
Defrost heater for very old Sears Coldspot 106.7627410 (Refrigerator & Freezer Repair)
by kboyette 3 years ago
No power to defrost heater during forced defrost mode (Kenmore Elite) (Refrigerator & Freezer Repair)
by skssf 4 years ago
How To Cycle Defrost Heater On Freezer (Refrigerator & Freezer Repair)
by DavyP49 5 years ago
Defrost heater question (Refrigerator & Freezer Repair)
by phildonnia 6 years ago
Defrost Heater always On. (Refrigerator & Freezer Repair)
by peterwapel 7 years ago
Defrost Heater (Refrigerator & Freezer Repair)
by mokalan 7 years ago
Defrost heater burning evaporator cover side gasket (Refrigerator & Freezer Repair)
by bahoefs59 7 years ago
Correct Readings for Thermostat/Defrost Heater (Refrigerator & Freezer Repair)
by willjohnston 8 years ago
Problem with Defrost Heater (Refrigerator & Freezer Repair)
by edkress 8 years ago
Defrost heater and thermostat (Refrigerator & Freezer Repair)
by Servicer123456 8 years ago
Defrost heater stays on during cooling cycle (Refrigerator & Freezer Repair)
by ragpicker 10 years ago
