5 Pages123>»
demark
#1 Posted : Monday, December 24, 2007 9:43:06 AM(UTC)
demark
I have a Kenmore dishwasher that appears to go through its cleaning cycle however there is soap residue left in dispenser and dishes are not clean. "Clean" light flashes 7 times--does that refer to a trouble code?
Thanks-Merry Christmas !!
#2 Posted : Monday, December 24, 2007 10:10:25 AM(UTC)
The "Clean" light, flashing 7 times means a problem in the heating circuit.
Reset the control as described in the tech's sheets (located in a pouch behind the bottom panel).
If it'll happen again, check the heating element and the high limit thermostat.
The model number you posted is incomplete.
Happy Holidays!
#3 Posted : Tuesday, December 25, 2007 12:51:04 AM(UTC)
Your hot water may be too cold, just increase temperature.
Open door, within 3 seconds hit high temp. scrub,energy saver dry, then repeat (if no such buttons press similar ones} Close door and press cancel. Good luck,Merry Christmas.
Neal
#4 Posted : Thursday, December 27, 2007 1:17:50 PM(UTC)
Neal
I have the same problem with my Kenmore. How do you reset the dishwasher as stated in the early post. There's nothing in my tech sheet.
Thanks.
#5 Posted : Thursday, December 27, 2007 1:47:43 PM(UTC)
Just follow the directions for Demark above
Neal
#6 Posted : Friday, December 28, 2007 1:52:02 AM(UTC)
Neal
I was able to reset the flashing green light. There was no error code shown afterwards. Then I ran the normal wash cycle. Took a few minutes
to start. On the screen started at 55, went down to 48 (?) then dropped to 2. Finished out the cycle. Afterwards the flashing green light. I could do the sequence all over again. Neal
#7 Posted : Friday, December 28, 2007 3:28:20 AM(UTC)
Check your service sheet. The dishwasher is sensing a bad heater. Check the heater and heater thermostat.
Neal
#8 Posted : Friday, December 28, 2007 3:53:02 AM(UTC)
Neal
I'm at work right now, How do I check those items? I'll check them later this evning. Thanks for your help.
#9 Posted : Friday, December 28, 2007 5:02:50 AM(UTC)
Crunch your model # in this site to get assembly info.
Neal
#10 Posted : Friday, December 28, 2007 4:05:21 PM(UTC)
Neal
Richappy, Where on this site do you find that info? First time user, Sorry.
5 Pages123>»
