rmahre
#1 Posted : Tuesday, June 9, 2009 10:41:09 AM(UTC)
rmahre
I am trying to repair a Thermadore Double oven, SCD272TB. The ovens actually work but the display is out. You can operate it blind (no display) if you know what you are doing.
I called the parts desk and it seems the double oven control unit is no longer stocked. Is there a sub component that can be ordered to repair this. Also, the homeowner pryed the glass away from the unit and it is loose and the black color was removed with the adhesive. Can I just get the glass for the unit?
bbloom0262
#2 Posted : Saturday, December 3, 2011 8:38:48 AM(UTC)
bbloom0262
hi
just wondering if you still need parts for this stove,
I have one that I would part out. you can reach me ,
bbloom0262@msn.com if interested thanks brian
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
thermador double oven no power to lower (Oven Repair (including Ranges and Cooktops))
by tomstir 3/18/2021 1:36:53 PM(UTC)
Thermador double oven no display (Oven Repair (including Ranges and Cooktops))
by daiwa0411 10/8/2020 7:12:03 AM(UTC)
Thermador Double Oven - Top Oven turns off F5 and F7 (Oven Repair (including Ranges and Cooktops))
by MattLester 2/9/2015 12:11:39 PM(UTC)
Thermador double oven F33 errors (Oven Repair (including Ranges and Cooktops))
by xyoptus 1/1/2015 11:26:32 PM(UTC)
Thermador Double Oven not working properly (Oven Repair (including Ranges and Cooktops))
by rxrep 12/28/2014 10:32:11 AM(UTC)
Thermador double oven control panel (Oven Repair (including Ranges and Cooktops))
by Malcolm Phillips 1/7/2013 4:40:27 PM(UTC)
Thermador Double Oven Self Clean (Oven Repair (including Ranges and Cooktops))
by canalking 1/28/2012 6:08:01 AM(UTC)
Thermador double oven (Oven Repair (including Ranges and Cooktops))
by cnlmerrell 1/10/2012 7:42:51 PM(UTC)
Thermador Double Oven (Oven Repair (including Ranges and Cooktops))
by manoog 1/8/2012 5:27:16 PM(UTC)
thermador double oven does not heat (Oven Repair (including Ranges and Cooktops))
by sport99 8/15/2010 6:07:27 PM(UTC)
60's Thermador double oven - low voltage (Oven Repair (including Ranges and Cooktops))
by doublebubble 4/4/2010 1:23:00 PM(UTC)
thermador double oven/microwave (Oven Repair (including Ranges and Cooktops))
by bocasue8 3/20/2009 2:39:22 PM(UTC)
Thermador Double Oven No self clean top (Oven Repair (including Ranges and Cooktops))
by JWLloyd 3/13/2009 8:16:45 AM(UTC)
by KMunday 3/6/2009 11:26:36 AM(UTC)
