jasporo
#1 Posted : Friday, November 16, 2007 3:57:08 AM(UTC)
jasporo
My Kenmore Dishwaser skips the Wash cycle and stops at the rinse cycle. Any Ideas on what the problem is?
#2 Posted : Friday, November 16, 2007 4:12:31 PM(UTC)
In order to provide the most accurate advise I need the complete model number of the dishwasher. Also I need as much description of the problem as possible,
Hammer head231
#3 Posted : Monday, June 8, 2009 2:32:10 PM(UTC)
Hammer head231
hello I have a KITCHEN AID DISHWASHER MODEL NUMBER KUDIOITJWHO IT WILL FILL WITH WATER THEN GO TO HEAT CYCLE FOR A FEW MINUTES THEN DRAIN
#4 Posted : Monday, June 8, 2009 2:36:49 PM(UTC)
Does it have any time intervals between heat and drain? Does it make any noise?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDI01TJWH0 | AppliancePartsPros.com
Hammer head231
#5 Posted : Monday, June 8, 2009 2:46:57 PM(UTC)
Hammer head231
no THERE IS NO DELAY FROM HEAT CYCLE AND DRAIN CYCLE IT DOES NOT MAKE ANY NOISE TILL DRAIN CYCLE STARTS
Hammer head231
#6 Posted : Monday, June 8, 2009 3:06:09 PM(UTC)
Hammer head231
#7 Posted : Monday, June 8, 2009 3:11:17 PM(UTC)
Check the wash pump motor and if there is nothing wrong then most likely the problem is a bad control board. The tech sheets might help.
