AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Dishwasher skips the wash cycle and stops at the rinse cycle
My Kenmore Dishwaser skips the Wash cycle and stops at the rinse cycle. Any Ideas on what the problem is?
In order to provide the most accurate advise I need the complete model number of the dishwasher. Also I need as much description of the problem as possible,
hello I have a KITCHEN AID DISHWASHER MODEL NUMBER KUDIOITJWHO IT WILL FILL WITH WATER THEN GO TO HEAT CYCLE FOR A FEW MINUTES THEN DRAIN
no THERE IS NO DELAY FROM HEAT CYCLE AND DRAIN CYCLE IT DOES NOT MAKE ANY NOISE TILL DRAIN CYCLE STARTS
Check the wash pump motor and if there is nothing wrong then most likely the problem is a bad control board. The tech sheets might help. Gene.
Dishwasher Repair
