jasporo
#1 Posted : 17 years ago
jasporo
My Kenmore Dishwaser skips the Wash cycle and stops at the rinse cycle. Any Ideas on what the problem is?
#2 Posted : 17 years ago
In order to provide the most accurate advise I need the complete model number of the dishwasher. Also I need as much description of the problem as possible,
Hammer head231
#3 Posted : 16 years ago
Hammer head231
hello I have a KITCHEN AID DISHWASHER MODEL NUMBER KUDIOITJWHO IT WILL FILL WITH WATER THEN GO TO HEAT CYCLE FOR A FEW MINUTES THEN DRAIN
#4 Posted : 16 years ago
Does it have any time intervals between heat and drain? Does it make any noise?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDI01TJWH0 | AppliancePartsPros.com
Hammer head231
#5 Posted : 16 years ago
Hammer head231
no THERE IS NO DELAY FROM HEAT CYCLE AND DRAIN CYCLE IT DOES NOT MAKE ANY NOISE TILL DRAIN CYCLE STARTS
Hammer head231
#6 Posted : 16 years ago
Hammer head231
#7 Posted : 16 years ago
Check the wash pump motor and if there is nothing wrong then most likely the problem is a bad control board. The tech sheets might help.
