daytonab99
#1 Posted : Thursday, June 4, 2009 7:57:17 AM(UTC)
daytonab99
Help. I Have A Crosley Fridge That Was Working Perfectly. Now The Freezer Part Has Build Up Of Water At The Bottom Of The Freezer Under The Meat Holder Pan. I Have To Chip And Clean The Ice From Here Every 4 Days. I Shut The Water Off So To See If The Water Would Stop, But It Hasn't. So Even If I Shut The Water For The Ice Maker And Water Off The Water Is Still Present At The Bottom Of The Freezer. Can Someone Please Tell Me What Would Cause This. I Checked The Fridge Pan And It Seems To Be Working And Drying Up The Water From The Fridge Side.
Very Puzzleling.
Thxs
Doug
woodchuckie
#2 Posted : Thursday, June 4, 2009 11:11:11 AM(UTC)
woodchuckie
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back inside the freezer.
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
rubber hose conector decayed and leaking. (Dishwasher Repair)
by Guest 2/25/2024 3:33:37 PM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Water reservoir is leaking and freezing (Refrigerator & Freezer Repair)
by Guest 2/24/2024 12:38:19 PM(UTC)
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
GE GSD2200Z01AD Leaking out front bottom (Dishwasher Repair)
by jappel 1/22/2024 7:02:46 AM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Leaking outside of refrigerator (Refrigerator & Freezer Repair)
by Guest 10/11/2023 3:47:19 AM(UTC)
