motkerry
#1 Posted : Tuesday, June 2, 2009 4:30:32 PM(UTC)
motkerry
The dryer makes a metal grinding sound when you turn it on. Is it a easy repair like a belt. Or is it a repair person job?
sidfink43
#2 Posted : Thursday, June 4, 2009 8:16:24 AM(UTC)
sidfink43
I think you can make the repair yourself if you a little mechanical experience. It is somewhat of a chore to tear down this machine, but nothing that cannot be done with time and patience.
Your biggest problem will be isolating the noise, so first release the belt and try to isolate it. As you take the machine apart keep turning the drum by hand (you have unplugged it haven't you!!) until you find it.
You will need a service manual. Here it is
http://frigidaireservicetips.com/pdfs/488_3.pdf
Good luck and let us know how it turns out.
Frigidaire Washer Dryer Combo GLET1142CS0 (Washer Repair)
by texashuman 11/16/2020 9:17:08 AM(UTC)
GE Washer Dryer Combo, clothes fell INSIDE how to get to them (Washer Repair)
by stilgarzero 10/27/2019 1:01:06 PM(UTC)
Electrolux Washer Dryer Combo (Dishwasher Repair)
by dhowe 11/10/2018 1:55:37 PM(UTC)
Frigidaire Washer Dryer Combo Not Working (Washer Repair)
by soshea42 7/10/2016 4:10:09 PM(UTC)
Frigidaire Stackable Washer Dryer Combo center (Washer Repair)
by megabyte5689 1/18/2016 2:56:21 PM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
Washer dryer combo acting up (Washer Repair)
by emshofk 11/26/2015 9:23:32 AM(UTC)
How to remove the tub from GE stackable washer dryer combo (Washer Repair)
by MSJORDAN 6/2/2015 11:42:26 AM(UTC)
Whirlpool Washer Dryer combo (Dryer Repair)
by TommyK 7/6/2014 7:29:56 AM(UTC)
Frigidaire washer dryer combo won't spin or drain (Washer Repair)
by MikeeD 1/24/2014 9:44:02 AM(UTC)
SE1000 washer dryer combo, dryer runs continuously no heat (Dryer Repair)
by mamasanders59 1/5/2014 1:41:28 PM(UTC)
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up (Dryer Repair)
by NVChickey 2/25/2012 10:50:02 PM(UTC)
replacing timer in washer dryer combo (Washer Repair)
by newlyretired 1/15/2012 9:30:36 AM(UTC)
washer dryer combos repair (Washer Repair)
by iblashaun 3/20/2011 8:37:38 PM(UTC)
by roscoe0807 12/18/2010 4:57:27 PM(UTC)
