cusorana
#1 Posted : Tuesday, June 2, 2009 2:15:21 PM(UTC)
cusorana
i bought a new bake element for the top oven and i installed it and it dosent wrk than i installed it at the bottom and it wrks fine there, but on the top oven it dosent wrk do you u think u can help me out with that??
#2 Posted : Tuesday, June 2, 2009 4:17:37 PM(UTC)
If neither the Bake nor the Broil are working then the problem is a bad thermal fuse (#37 on the diagram) on the back of the oven.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RBD245PDQ11 | AppliancePartsPros.com
cusorana
#3 Posted : Tuesday, June 2, 2009 6:23:02 PM(UTC)
cusorana
the broil is still working in the upper oven but not the bake. what do you think is the problem? does this oven have 2 fuses? i can see the one on the lower oven but i dont see the one on the upper oven. when the bake element burnt a small screw fell on the bake element and it made a hole in it and a flame inside the oven. everything else was working after that, except the bake element which i replaced it with a new one. i thought that the new bake element was bad and i installed it on the lower oven and its works but it doesnt work on the upper oven.
I need some help to fix this problem please. thank you.
cusorana
#4 Posted : Wednesday, June 3, 2009 6:46:51 PM(UTC)
cusorana
can someone please help me with my question????
#5 Posted : Wednesday, June 3, 2009 9:26:40 PM(UTC)
If there is only Bake does not work then most likely the problem is a bad control board.
- The part number for the control board is AP3767567
OEM or Aftermarket Replacement Bake Element? (Oven Repair (including Ranges and Cooktops))
by lbb78 4/18/2024 10:05:55 AM(UTC)
Bake Element Debris? (Oven Repair (including Ranges and Cooktops))
by Dan0tn 1/23/2024 9:18:53 AM(UTC)
GE oven bake element (Oven Repair (including Ranges and Cooktops))
by 72yrsoldwoman 10/27/2023 6:22:03 PM(UTC)
GE Hotpoint Stove Bake Element not working (Oven Repair (including Ranges and Cooktops))
by Guest 3/21/2023 10:17:36 AM(UTC)
Using a Broiler element to replace a bad Bake Element (Oven Repair (including Ranges and Cooktops))
by Guest 11/22/2021 2:49:19 PM(UTC)
Frigidaire FGEW3065PDF bake element (Oven Repair (including Ranges and Cooktops))
by crowsons 10/30/2021 3:22:26 PM(UTC)
Hidden bake element whirlpool range (Oven Repair (including Ranges and Cooktops))
by Guest 8/12/2021 10:05:04 AM(UTC)
Modern Maid bake Element Replacement (Oven Repair (including Ranges and Cooktops))
by Gkvaas 4/22/2020 4:00:01 PM(UTC)
Viking Bake Element (Oven Repair (including Ranges and Cooktops))
by djb16 2/23/2020 7:28:49 AM(UTC)
Kenmore Electric Wall Oven 790.41003603 - Broil AND Bake elements won't heat (Oven Repair (including Ranges and Cooktops))
by acehigh21 7/28/2019 11:14:25 AM(UTC)
Kitchenaid Bake Element Problem (Oven Repair (including Ranges and Cooktops))
by mawaw 3/2/2019 10:12:44 AM(UTC)
Replace bake element on electric range/oven (Oven Repair (including Ranges and Cooktops))
by bad Dog 2/24/2019 9:17:21 AM(UTC)
How to replace hidden bake element in GE JKP30SM1SS (Oven Repair (including Ranges and Cooktops))
by scarpenter444 9/6/2018 5:01:15 AM(UTC)
Bake element on Wall Oven (Oven Repair (including Ranges and Cooktops))
by Enore 3/4/2018 11:26:13 AM(UTC)
Bake element not receiving power (Oven Repair (including Ranges and Cooktops))
by tiredoftakeout 3/11/2017 3:03:02 PM(UTC)
