blackcote
#1 Posted : Friday, May 29, 2009 10:43:37 AM(UTC)
blackcote
Turned the oven on to bake and it suddenly got a mind of its own it turned to clean mode said the door was locked and wasn't. I had to unplug the stove when it cooled a little the door did lock. Waited till the oven cooled down some and plugged back in. It cleared all codes but the oven was still heating. What am I looking at to replace ? Or would it be better to buy a new one?
#2 Posted : Friday, May 29, 2009 1:29:06 PM(UTC)
Sounds like the control board has gone bad. The model number you posted is incomplete.
blackcote
#3 Posted : Friday, May 29, 2009 6:29:23 PM(UTC)
blackcote
Thanks for the quick reply sorry I forgot the 665. 95775890
#4 Posted : Friday, May 29, 2009 6:55:50 PM(UTC)
Those control boards are also different in color. What is the color of the key panel in your range?
blackcote
#5 Posted : Saturday, May 30, 2009 3:03:25 PM(UTC)
blackcote
The face is white. I took notice the broiler is the only thing that turns on by itself. Can I unhook that temporarily so I can use the cooktop
#6 Posted : Saturday, May 30, 2009 5:07:50 PM(UTC)
Originally Posted by: blackcote Go to Quoted Post
...Can I unhook that temporarily so I can use the cooktop...
It is possible, but I do not know how to do it with your range because I do not have the wiring diagram. You have to find the live wires connected to the control board, draw a picture of their connection to the control board, so will remember how to connect them to the new part, disconnect and insulate them.
- The part number for the control board is AP3119177
blackcote
#7 Posted : Saturday, May 30, 2009 5:14:20 PM(UTC)
blackcote
Thanks Gene you have really been helpful. It is much appreciated
#8 Posted : Saturday, May 30, 2009 10:29:52 PM(UTC)
Guest (4)
GE Oven Won't Shut Off (Oven Repair (including Ranges and Cooktops))
by Tracy0407 1/5/2013 4:38:06 PM(UTC)
Kitchenaid KESC307HWH6 - oven won't shut off (Oven Repair (including Ranges and Cooktops))
by perpetualapprentice 3/24/2012 9:05:38 AM(UTC)
by swalczak 9/21/2011 5:43:18 AM(UTC)
KitchenAid oven won't shut off (Oven Repair (including Ranges and Cooktops))
Belarus Norman G. 2/21/2011 4:06:59 PM(UTC)
Oven won't shut off! (Oven Repair (including Ranges and Cooktops))
by mikeamondo 12/2/2010 5:02:49 PM(UTC)
Oven won't shut off & goes into cleaning mode by itself (Oven Repair (including Ranges and Cooktops))
by CyberDad 12/15/2009 10:18:28 AM(UTC)
by laarman 10/8/2009 9:53:48 AM(UTC)
Oven won't shut off (Oven Repair (including Ranges and Cooktops))
by charlie3198 5/27/2009 12:31:56 PM(UTC)
Amana electric oven won't shut off (Oven Repair (including Ranges and Cooktops))
by Kirkfarley 4/25/2009 6:34:23 AM(UTC)
by boater08 11/22/2008 9:22:02 AM(UTC)
by RickG 1/21/2008 8:15:58 AM(UTC)
