JSK
#1 Posted : Friday, May 29, 2009 5:34:11 AM(UTC)
JSK
Hello. The machine fills and washes fine, when the spin cycle starts after the wash it is not fast enough for the fabric softner to dispense. Also after the rinse the clothes are still very wet. This happens all the time now, full load or light load makes no difference. Spin selector button is set on 'normal'. Does the machine need a belt?
#2 Posted : Friday, May 29, 2009 6:07:33 PM(UTC)
It can be a bad belt, insufficient belt tension or a foreign object stuck between the inner and the outer tubs.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE GWS645RHS0 | AppliancePartsPros.com
JSK
#3 Posted : Monday, June 1, 2009 5:13:06 AM(UTC)
JSK
Thank you for your help. I will check what you suggested.
Whirlpool washer spins slowly and noisily (Washer Repair)
by chuckledog 3/3/2017 6:26:54 AM(UTC)
Kenmore top load spins slowly (Washer Repair)
by rivertrash 9/18/2016 10:35:42 AM(UTC)
Fridgidaire Affinity Washer Spins slowly (Washer Repair)
by quichua007 4/16/2015 12:26:02 AM(UTC)
Estate Washer spins slowly (Washer Repair)
by Draven53365 5/7/2014 8:53:38 AM(UTC)
Help! Washer won't drain and spins slowly (Washer Repair)
by chevrolady 8/27/2013 2:16:26 PM(UTC)
Washer Spins Slowly (Washer Repair)
by dabowler 7/26/2013 6:24:03 AM(UTC)
Whirlpool Washer spins SLOWLY even after putting in new clutch (Washer Repair)
by babaasheri 1/15/2013 5:24:11 PM(UTC)
Maytag washer spins slowly (Washer Repair)
by rickw51 5/8/2012 1:36:10 PM(UTC)
washer spins slowly and doesn't drain large load (Washer Repair)
by kbarnitz 4/19/2010 9:09:58 AM(UTC)
Washer Spins slowly stops and restarts (Washer Repair)
by eegone 3/15/2010 8:01:08 PM(UTC)
by TPK 8/6/2009 7:36:27 AM(UTC)
Electric dryer spins slowly (Dryer Repair)
by bumhunter 3/13/2009 2:39:46 PM(UTC)
GE Washer 2006 Only Spins Slowly (Washer Repair)
by juli300 7/3/2008 10:29:24 AM(UTC)
Whirlpool Spins Slowly Sometimes not at all (Washer Repair)
by XtremeRob 2/9/2008 7:45:03 AM(UTC)
Kenmore spins slowly (Washer Repair)
by DaniB 2/4/2008 7:05:56 AM(UTC)
