Dishwasher has no lights...wont start. Checked power. There is power until after the door switch to the thermal fuse but i dont get anything after. Is it that simple that the thermal fuse needs to be replaced or is there something else i should be checking.
Replacement parts for DU943PWKTO models | AppliancePartsPros.comYes it could be as simple as replacing the thermal fuse (Item 4 in Section 1). You checked power so you probably have a meter, just pull the fuse and check it. It should be 0 ohms. If it is blown when you replace it be sure to use the new harness that comes with it. |
THIS FORUM IS DEAD!!!!!!! |
thank you for responding. it was my thermal fuse after all. but it was too good to be true. i cannot for the life of me put the door back together. are there any tips, solutions, etc... that anyone knows... whirlpool dishwasher model no. du943pwkt0....thanks
i was able to finally get the door back together....but thank you for responding. i appreciate it.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 3 time(s) in 3 post(s)
I just picked up a Danby DDW631SDB Countertop Dishwasher. When I got it I was told that it leaks out the bottom. I opened it up to find a piece is broken and it looks like a hose is missing. I can attach the photo I took, but I'm looking for a photo of the base setup from factory. If anyone can find one please send it to me. Edited by user Thursday, September 29, 2022 4:28:54 PM(UTC)
| Reason: Corrected information.
