AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Less than two year old top load Maytag Washer Lid Hinge broken
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 1 time(s) in 1 post(s)
New Maytag top load Bravos in April 2020. I want to make sure this is the same break, my hinge did not break (apparently yet) on either side but on the right side (facing machine) the lid is cracked all over the rear corner. It is staying together, I did just have a problem with the lid switch that I fixed without replacement, but I saw this message thread and wanted to piggyback onto it. I thought the cracked lid may be part of the switch problem, just not sure. I still have all the pieces together so I am gonna try crazy glueing that corner.
Rank: Guest
I’m having these same problems. That’s ridiculous to have to pay for these repairs. Maytag should fix them!!
Rank: Guest
Same problem. Plastic around the left hinge on my top loading Maytag broke. Now lid lock doesn’t work correctly.
Rank: Guest
Same issue withe top load washer purchased in 2019 lid hinge has broken twice called customer care and they woul not replace defective part….. very disappointed with may tag quality and will never buy Maytag again….. In the future I am only buying SPEED QUEEN WITH MEATAL LID ONLY🇺🇸
My Maytag washer model MVWB765FW3 lid at broken at the hinge on the left side. Purchased 3/9/2019. No recall??? Just a repair estimate of $504 for a 3 yr old Maytag?
Rank: Guest
Same problem here. Left hing broken, cheap plastic. We bought a new Maytag set when we built a new house 2 years age. We thought we were buying the best, Maytag once stood for quality and service but no more.
Rank: Guest
I just stumbled upon this thread when looking for a replacement lid for a MVWB835DW4 Maytag Washer. The lid cracked, you guessed it, on the left hinge. We've been dealing with it by holding down the lid when starting the washer until it's locked, but it'd be nice if we didn't have to do that anymore. I was beginning to think we caused it by putting something heavy on the lid by accident, looks like that's not the case. I am glad we're not the only one, but wish they had a fix for this. What's the point of purchasing a new lid if it's going to happen again? It's not a cheap part or easy to obtain. This is a nightmare! Maytag needs to be accountable.
Rank: Guest
same issue - seems the damper needs to be disabled,
Washer Repair
