akhan
#1 Posted : Saturday, October 6, 2018 8:30:46 AM(UTC)
akhan
My dishwasher will not fill, I’ve changed the inlet water valve, checked the float switch which works,. No power to inlet valve so I thought it maybe the float switch, however when testing continuity, this worked fine. The machine appears to be working but cannot hear the unit going into the cycles for water to fill into the machine. Checked door latch all ok, Any additional help would be grateful.
akhan
#2 Posted : Tuesday, October 9, 2018 10:53:06 AM(UTC)
akhan
Hi Ohm
the problem was the timer, there was no continuity to the motor part, the one that has two pin plug. Installed a new timer unit and the dishwasher is working again. Just a heads up to anyone else that may have this problem, when I finished installing everything the soap dispenser door would not close. Checked the springs- all ok, finally resolved problem by figuring out the old timer unit had a plastic wheel, which did not come with the new unit. Re attached the wheel to the new unit and presto, the soap door now closes.
thanks again.
Billy889
#3 Posted : Tuesday, October 9, 2018 11:06:11 AM(UTC)
Billy889
Originally Posted by: akhan Go to Quoted Post
Hi Ohm
thanks again.
+1
UserPostedImage
nestof3
#4 Posted : Saturday, October 27, 2018 12:37:41 PM(UTC)
nestof3
United States
Yesterday, water filled in the bottom of the unit but didn’t spray. Today, water isn’t even entering the unit.
We have tested the float switch, the water hose, and the water inlet valve (which we placed).
Whirlpool WDF750SAYW1
Guest (4)
Bosch Dishwasher does not fill (Dishwasher Repair)
by crockega 2/7/2011 8:46:29 AM(UTC)
Dishwasher does not fill with water (Dishwasher Repair)
by HarryW 11/19/2010 6:18:20 PM(UTC)
Dishwasher does not fill with water - spray arms not moving (Dishwasher Repair)
by gilwood 7/16/2010 6:43:27 AM(UTC)
dishwasher does not fill (Dishwasher Repair)
by kbappliance 7/8/2009 9:49:21 AM(UTC)
Dishwasher does not fill all the way (Dishwasher Repair)
by ljhnstn 5/27/2009 9:41:22 AM(UTC)
dishwasher does not fill with water - missing float (Dishwasher Repair)
by TOM COTTER 3/13/2009 3:20:30 AM(UTC)
