CRUZANGEL
#1 Posted : Thursday, September 13, 2018 7:47:16 PM(UTC)
CRUZANGEL
The clean Air Vent filter light comes on, the filter has been cleaned, vents are not blocked, however light continues to come on when the dryer is turned on, the dryer comes on but nothing happens except for the clean vent light coming on?
panel123
#2 Posted : Saturday, September 15, 2018 9:10:25 AM(UTC)
panel123
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
samsung dryer Dv48H (Dryer Repair)
by Guest 2/27/2024 6:11:07 PM(UTC)
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
Samsung Dryer Test Mode (Dryer Repair)
by stanw 8/8/2023 2:36:51 PM(UTC)
Samsung Dryer possibly in flood throwing HC code (Dryer Repair)
by QuickPuppy 2/16/2023 7:41:27 AM(UTC)
Samsung dryer starts but won't turn drum or heat (Dryer Repair)
by coach_hall_42 1/22/2023 1:39:56 PM(UTC)
Samsung dryer stuck in continuous cycle (Dryer Repair)
by Guest 8/26/2022 6:18:39 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
Runs 3Min Stops-OR-Runs & Doesn't heat Samsung Dryer DV42H5000EW/A3-0000 (Dryer Repair)
by Guest 2/18/2022 11:57:14 AM(UTC)
Samsung dryer conversion to 50hz (Dryer Repair)
by Hlaudio 1/13/2022 2:57:31 AM(UTC)
Samsung dryer DV42H5200 still not heating after replacing all components (Dryer Repair)
by Guest 1/9/2022 11:26:52 AM(UTC)
Samsung Dryer HE error (Dryer Repair)
by hoagieh 10/23/2021 1:17:45 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
Samsung Dryer Error Code "HE" (Dryer Repair)
by czechmka 7/7/2021 11:01:22 AM(UTC)
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
