OH44281
#1 Posted : Thursday, January 4, 2018 1:14:18 PM(UTC)
OH44281
Our over the range microwave worked fine this morning, but this evening it has no signs of life.
Last thing made in it was probably a cup of cocoa. Three minutes to warm up the milk.
This past weekend it did feel super hot inside, even when it had not been used for quite a long time, possibly hours. We thought maybe it was from having the light on underneath, but were not sure. The next day it was fine and has been fine for days. Until today.
We checked to make sure it wasn't lack of electric to the plug.
I'm not sure what to do?
I watched a couple of videos on YouTube but do not know if it's a thermal fuse or a thermostat (am trying to find out if these two are the same thing?) or something else completely.
ThatGuy
#2 Posted : Thursday, January 4, 2018 1:59:58 PM(UTC)
ThatGuy
Groups: Expert
United States
It could be a lot of things, Bad electrical connection inside the MW. A bad line fuse, a bad thermal fuse, a bad transformer on the board, or even a blown cavity fuse if it has one.
This board has the power fuses on it.
GE WB27X11160 Assy Noise Filter - AppliancePartsPros.com
This shows all the parts inside the MW.
Parts for GE JNM1951SR1SS: Microwave Parts - AppliancePartsPros.com
Thermal cutout on the magnetron.
GE WB27X11095 Tco-Magnetron - AppliancePartsPros.com
This might be in circuit too. I don't have the wiring diagram so I can't tell.
GE WB20X10060 Thermostat - AppliancePartsPros.com
OH44281
#3 Posted : Thursday, January 4, 2018 2:35:54 PM(UTC)
OH44281
Thank you. I think I am in over my head. :)
#4 Posted : Thursday, January 4, 2018 9:25:43 PM(UTC)
Originally Posted by: OH44281 Go to Quoted Post
1. ...This past weekend it did feel super hot inside, even when it had not been used for quite a long time, possibly hours. We thought maybe it was from having the light on underneath, but were not sure...
2....I'm not sure what to do?...
Just to add my 2 cents...
1. Keeping the surface lights on for a long time will definitely heat up the microwave interior. It's not recommended by the manufacturer.
2. The first thing you may want to check is the line fuse. The fuse is located on a receptacle near the top of the noise filter board and is common to all functions and door switches.
To remove the fuse:
1. Disconnect power to the microwave oven.
2. Remove grille assembly.
3. Remove control panel vent plate.
4. Remove the control panel assembly.
5. Remove the fuse. (The lower one.)
6. Using a multimeter check the fuse for continuity.
The fuse Part number: AP2631556
LG Microwave dead (Microwave Repair)
by Bob1946 4/20/2015 7:32:12 AM(UTC)
by EBrink3 7/3/2013 12:37:15 PM(UTC)
Ge Jvm1653sh06 Range Hood Microwave Dead (Microwave Repair)
by larrywick 10/24/2012 12:37:07 PM(UTC)
by dtlee 1/1/2012 2:21:36 PM(UTC)
Whirlpool Microwave Dead (Microwave Repair)
by anirpat 9/13/2011 8:45:49 AM(UTC)
Microwave Dead in the Water (Microwave Repair)
by pmaldrum 2/17/2011 9:41:13 AM(UTC)
Microwave DEAD! (Microwave Repair)
by HeyYoLeeroy 11/14/2010 7:05:05 PM(UTC)
GE Microwave Dead (Microwave Repair)
by slysbob 9/21/2010 6:43:23 AM(UTC)
by cjohn39 7/8/2010 11:08:47 AM(UTC)
Whirlpool Microwave DEAD! (Microwave Repair)
by themalones1995@gmail.com 2/24/2010 12:58:13 PM(UTC)
Kenmore Elite Microwave dead (Microwave Repair)
by Mayfair 6/16/2009 10:26:43 AM(UTC)
Sharp Carousel Microwave dead after potato fire (Microwave Repair)
by repm0e 6/6/2009 11:20:55 PM(UTC)
Maytag microwave dead (Microwave Repair)
by WarMar 1/2/2009 8:18:59 AM(UTC)
Microwave Dead - Whirlpool (Microwave Repair)
by ART1 11/4/2008 12:43:14 PM(UTC)
by dolfanjhn 11/2/2008 11:16:57 AM(UTC)
