My Frigidaire microwave just died overnight. no clock, no lights, no power.It worked fine the evening before, then was dead in the morning.
replace the fuse see if it blows again you can get those at radio shack 250 volt either 15 or 20 amp get 3 or 4 of em
I have Frigidaire PLMV168KC4 with the same problem. I've taken the touch control panel off to see the wiring but can't find a fuse. Originally Posted by: v2k04  replace the fuse see if it blows again you can get those at radio shack 250 volt either 15 or 20 amp get 3 or 4 of em
I have model PMLV169DCC and can't find the fuse either. I also have a microwave that seems to be dead. I have power to the control board but nothing is energized.
