carribquen
#1 Posted : Thursday, May 21, 2009 12:55:31 PM(UTC)
carribquen
Just finished drying a load of clothes, started another, closed door and turned start switch and it just buzzed! Normally all I would do is turn (knob is like it has a spring on it)let it go and the knob is back in position, dryer starts! This is a front load, electric hotpoint, 3 cycle, heavy duty dryer. Please help!:o
#2 Posted : Saturday, May 23, 2009 1:17:05 AM(UTC)
Often the buzz is the motor trying to start.
This may take 2 people.
Open the door and try turning the drum by hand, should turn fairly easily.
If OK
Hold the door switch closed.
Try to start the unit.
When it buzzes turn the drum in the correct direction by hand
Watch your knuckles in case it starts up
If it starts then odds are high that you need a new motor.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
