i replaced the control board on my epic z dryer an it worked fine for about 3 days then it quit heating does anyone know what the problem would be ?
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
What were the symptoms that caused you to replace the control board? It may be a bad heater relay on the control board or it might be a bad heating element, or a bad thermostat.
