PeterEmma
#1 Posted : Saturday, October 15, 2016 11:22:55 AM(UTC)
PeterEmma
My washer makes a noise when agitating and the drum does move back and forth during the agitating. Drum works when spinning and trains , changed the cuppler which was fine any ways, agitator dogs teeth are all good ...anyone
PeterEmma
#2 Posted : Saturday, October 15, 2016 11:23:59 AM(UTC)
PeterEmma
Sorry drum does not move back and forth but does spin fine otherwise
ThatGuy
#3 Posted : Saturday, October 15, 2016 12:01:34 PM(UTC)
ThatGuy
Groups: Expert
United States
A model number would be helpful.
Are you saying the agitator isn't moving, but the washer makes a noise during agitation?
Is the noise kind of a "riipp, riipp" like gears grinding?
PeterEmma
#4 Posted : Saturday, October 15, 2016 12:20:11 PM(UTC)
PeterEmma
No it agitates but the drum does not move back and forth when the agitator is doing its thing. The is more a banging sound. Model number is KAWS700LQ0
Motor coupler was changed
The washer spins and drains fine and does not make any noises except when agitating
ThatGuy
#5 Posted : Sunday, October 16, 2016 2:57:36 AM(UTC)
ThatGuy
Groups: Expert
United States
Please look at this diagram and tell me which part (drum?) is not moving right.
Parts for KitchenAid KAWS700LQ0: Agitator, Basket and Tub Parts - AppliancePartsPros.com
PeterEmma
#6 Posted : Sunday, October 16, 2016 3:01:08 AM(UTC)
PeterEmma
Yes drum does not move during the agitating cycle
ThatGuy
#7 Posted : Sunday, October 16, 2016 3:34:29 AM(UTC)
ThatGuy
Groups: Expert
United States
Which part is "DRUM"???
look at the parts diagram and tell me the real name of the part you keep calling "DRUM".
If you can't do that, we are done here.
PeterEmma
#8 Posted : Sunday, October 16, 2016 3:45:00 AM(UTC)
PeterEmma
The tub then. The entire agitator works fine but when it agitating the tub is suppose to move back and forth but it does not only the agitator moves.
ThatGuy
#9 Posted : Sunday, October 16, 2016 4:50:46 AM(UTC)
ThatGuy
Groups: Expert
United States
The tub is locked in place by a brake when the washer is agitating.
That brake is released when the washer goes into its spin cycle. When the spin cycle ends the brake slows down and stops the tub.
That is normal operation.
PeterEmma
#10 Posted : Sunday, October 16, 2016 5:21:47 AM(UTC)
PeterEmma
Okay thanks my wife just told me the agitator is only moving in one direction she thought the tub was suppose to move as well. Clothes get tangled and it is in the agitating cycle that the noise happens. Looks like I need a new agitator kit
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
Belarus Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
