me shaw
#1 Posted : Thursday, July 21, 2016 4:35:25 PM(UTC)
me shaw
My dryer stopped heating. Ordered new element from this site. Fast shipping! Replaced element..this did not solve my problem. Tested old element and it is still good. Did some research and tested all the thermostats. All good. The dryer will not run if the Wrinkle Care switch is off. Any ideas? Could really use the help!
brobriffin
#2 Posted : Friday, July 22, 2016 5:40:58 AM(UTC)
brobriffin
Man
United States
The first thing now to look at is to see if you have 220/240 v coming in to the machine. [Note: only perform a test for voltage if you 100% sure how to do so. If not please call a service technician.] If you do have 220 / 240 at the terminal block look for any burnt wiring. One lead L1 runs the timer and side 1 of the heating element. The second lead L2 runs through a centrifugal switch on the motor to side 2 of the heating element. If both sides are not receiving 110 / 120 v the heating element won't work. With that said your heating issue coupled with the issue of not running unless the wrinkle shield is on, I suspect your timer is bad. You can purchase a replacement here if it is bad GE WE4M527 Timer - AppliancePartsPros.com
Again do not attempt to check high voltage if you are not familiar with the process.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
