Gaylor Wofford
#1 Posted : Sunday, January 31, 2016 7:22:35 AM(UTC)
Gaylor Wofford
code f1 pops up everytime I push starts:mad:
#2 Posted: : Monday, February 1, 2016 1:19:33 AM(UTC)
Nothing comes up with the given model number.
Please check it.
Find your model number - AppliancePartsPros.com
Whirlpool numbers are usually a couple letters at the start then some numerals and then some letters at the end.
PatGalvin
#3 Posted : Monday, February 1, 2016 1:20:40 PM(UTC)
PatGalvin
Denman
This happened to me on my Whirlpool Duet dryer just last week. And happened to my brother a couple months ago. You'll fine a video on this website showing you how to remove the control board. You'll see one terminal on the back of the PCB (under the large relay) that is burned. Just clean it a bit and put a drop of solder on it and reinstall the control board. Worked like a charm for me just yesterday. Board is super easy to access. Just remove two or three sheet metal screws on top back of dryer and remove top cover. Control Board is easy to remove. Just remove each plug on wiring harness. Last two plugs can be removed after the Board is removed from the white plastic carrier.
BTW, I think it is HorshSh*t that all these dryers have the same board failures. A new Board costs at least $200 on this website and much more from Sears. If it happens to so many boards, it should be a factory recall.
PatGalvin
#4 Posted : Monday, February 1, 2016 1:21:17 PM(UTC)
PatGalvin
BTW, send me a PM if you need help with this.
Pat
LG LMXS30776S/03 refer error code F1 (Refrigerator & Freezer Repair)
by FishinBob 12/9/2022 8:36:17 AM(UTC)
Oven beeping and code f11 (Oven Repair (including Ranges and Cooktops))
by bigge31566 11/6/2017 5:41:34 PM(UTC)
Fridgidaire Range Error code F10. (Oven Repair (including Ranges and Cooktops))
by 22pistol 3/2/2017 5:18:33 PM(UTC)
Whirlpool error code f1e2 (Washer Repair)
by Melodyvanatti 2/16/2017 8:32:38 AM(UTC)
Lid lock flashing - error code F1 E2 (Washer Repair)
by burritoman 8/22/2016 4:53:48 PM(UTC)
whirlpool microwave code F1E4 mw power relay (Microwave Repair)
by sja527 12/21/2014 3:36:17 PM(UTC)
Thermador Fault Code F11 (Oven Repair (including Ranges and Cooktops))
by DFH 11/29/2014 1:29:03 PM(UTC)
Whirlpool code F1E5 (Microwave Repair)
by Hedd 4/28/2014 9:36:54 AM(UTC)
Frigidaire error code f11 (Oven Repair (including Ranges and Cooktops))
by bbcci 8/9/2013 4:45:22 AM(UTC)
Bottom element not working code F10 (Oven Repair (including Ranges and Cooktops))
by CHEVY5637 6/19/2013 5:59:56 PM(UTC)
Whirlpool Wash Error Code F11 (Washer Repair)
by majorbourne 4/29/2013 6:13:55 PM(UTC)
Error code F10? (Oven Repair (including Ranges and Cooktops))
by cs86 3/16/2013 12:20:48 PM(UTC)
Code F1 (Oven Repair (including Ranges and Cooktops))
by ElaJerm 8/28/2012 3:32:51 PM(UTC)
Whirlpool Cambrio Automatic washer error code F1 (Washer Repair)
by dishwasher6 7/24/2012 4:46:21 PM(UTC)
Error Code F13 (Oven Repair (including Ranges and Cooktops))
by George Karschney 3/21/2012 11:24:28 AM(UTC)
