Hedd
#1 Posted : Monday, April 28, 2014 9:36:54 AM(UTC)
Hedd
The Microwave is between 1-2 years old. It just started giving a F1E5 code. It runs for about 10 seconds total before giving the code, after about three seconds makes a click noise.
I purchased a new inverter part #AP5645075 but this did not fix the problem. Any suggestions on what I should try next?
Thank you,
Jonathan
Hedd
#2 Posted : Friday, May 23, 2014 2:35:51 PM(UTC)
Hedd
I replaced the magnetron and it's working now. The old magnetron has a burned hole in the end that should not be there.
Guest (4)
