Dan4180
#1 Posted : Sunday, December 13, 2015 7:24:28 AM(UTC)
Dan4180
I need to replace my timer. The part number listed on the instructions is part 3979703 REV REL. I can't find this part to purchase. Can you find it or know an alternative part that will work? Thank you.
I can't find the model number of my dryer. If you need that can you advise where it's located?
#2 Posted : Sunday, December 13, 2015 8:08:22 AM(UTC)
This may help you find the model number
Find your model number - AppliancePartsPros.com
The number you gave comes up as a wiring diagram not a timer.
take the numbers off of the timer if you cannot find the model number.
Also what is wrong with the timer.
If it is a timer advancing problem and it advances in timed dry but not in auto modes then odds are it is not the timer.
Whirlpool dryer timer knob (Dryer Repair)
by robertjhebert 10/27/2019 8:50:18 AM(UTC)
Whirlpool dryer timer won't stop running. (Dryer Repair)
by ppipowerclass 4/2/2018 2:18:22 PM(UTC)
Whirlpool Dryer Timer not advancing (Dryer Repair)
by jconkl02 5/9/2016 9:47:22 AM(UTC)
Whirlpool dryer timer (Dryer Repair)
by 68Vert 11/11/2011 4:41:57 PM(UTC)
Whirlpool dryer timer cycle endless (Dryer Repair)
by PAplumber 7/23/2011 10:42:35 AM(UTC)
Whirlpool dryer timer won't work sometimes (Dryer Repair)
by Baudretsch 12/18/2010 4:37:48 PM(UTC)
whirlpool dryer timer (Dryer Repair)
by junior10 11/21/2010 8:30:30 AM(UTC)
Whirlpool Dryer timer test good but not working (Dryer Repair)
by ctbasscatcher 9/4/2010 11:23:15 AM(UTC)
Whirlpool dryer timer advances occasionally, but usually does not shut off (Dryer Repair)
by lynndicken 8/19/2010 5:13:23 AM(UTC)
Whirlpool Dryer Timer not advancing / no heat (Dryer Repair)
by lady 11/19/2009 4:56:47 PM(UTC)
Whirlpool Dryer Timer Wiring (Dryer Repair)
by leeke02 9/11/2009 4:09:39 AM(UTC)
whirlpool dryer timer not moving (Dryer Repair)
by jonathan8 3/26/2009 6:00:58 AM(UTC)
Whirlpool Dryer timer runs backwards (Dryer Repair)
by PattyL 3/24/2009 10:36:58 AM(UTC)
by jackpetty72@yahoo.com 12/17/2008 2:18:12 PM(UTC)
Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes. (Dryer Repair)
by XtremeRob 2/9/2008 8:07:08 AM(UTC)
