I need to replace my timer. The part number listed on the instructions is part 3979703 REV REL. I can't find this part to purchase. Can you find it or know an alternative part that will work? Thank you.
I can't find the model number of my dryer. If you need that can you advise where it's located?
This may help you find the model number Find your model number - AppliancePartsPros.comThe number you gave comes up as a wiring diagram not a timer. take the numbers off of the timer if you cannot find the model number. Also what is wrong with the timer. If it is a timer advancing problem and it advances in timed dry but not in auto modes then odds are it is not the timer. |
THIS FORUM IS DEAD!!!!!!! |
