doctorcoven
#1 Posted : Saturday, December 5, 2015 8:19:27 AM(UTC)
doctorcoven
Cook top and grill work. Oven will heat to 300 but no further.
I assume the element works since it heats at all, is there a thermostat or some other sensor that decides when to regulate current to element? Is there a control board that serves this purpose?
#2 Posted : Saturday, December 5, 2015 9:48:27 AM(UTC)
A model number would help.
Find your model number - AppliancePartsPros.com
[COLOR="Blue"]assume the element works since it heats at all, [/COLOR]
On many units they switch back and forth between the bake and the broil elements so maybe one element is no good.
[COLOR="Blue"]is there a thermostat or some other sensor that decides when to regulate current to element?[/COLOR]
Yes there is an oven sensor. It is a tube that extends into the oven top/back.
It shuld measure about 1100 ohms at room temperature.
[COLOR="Blue"] Is there a control board that serves this purpose?[/COLOR]
Cannot say some units do and others do not.
Jenn air s160 tripping gfci breaker (Oven Repair (including Ranges and Cooktops))
by Guest 3/15/2024 5:25:33 PM(UTC)
JFC2290VEM Jenn Air Fridge too cold (Refrigerator & Freezer Repair)
by investwisely 1/23/2024 5:40:51 PM(UTC)
Jenn Air JDS9860CDS00 (Oven Repair (including Ranges and Cooktops))
by Guest 12/29/2023 10:37:36 AM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Dual Burner Cap for Jenn Aire Model JGS8860BDP is no longer made (Oven Repair (including Ranges and Cooktops))
by SVCirnee 11/20/2022 11:38:40 AM(UTC)
Jenn Air Fridge JCD2595WES02 Ice not droppiing (Refrigerator & Freezer Repair)
by peabean 7/5/2022 5:42:11 PM(UTC)
Jenn Air Range spark module keeps sparking with switch turned off (Oven Repair (including Ranges and Cooktops))
by Guest 2/16/2022 11:48:26 AM(UTC)
Jenn Air JCD2389GTB (Refrigerator & Freezer Repair)
by tevans84025 2/1/2022 8:11:29 AM(UTC)
Jenn Air SVD48600P Downdraft not working, need troubleshooting help (Oven Repair (including Ranges and Cooktops))
by Don Tumas 1/5/2022 5:53:18 PM(UTC)
Jenn Air Double Oven Malfunctioning (Oven Repair (including Ranges and Cooktops))
by Guest 12/27/2021 3:48:46 PM(UTC)
Jenn Air JFX2897DRP00 (Refrigerator & Freezer Repair)
by jboogieman 12/20/2021 1:19:48 PM(UTC)
Jenn Air Dishwasher soap dispenser door wont open (Dishwasher Repair)
by Guest 10/22/2021 5:22:26 AM(UTC)
Jenn Air C301 (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2021 10:36:05 AM(UTC)
Jenn Air JFC2089HES (Refrigerator & Freezer Repair)
by Guest 8/30/2021 6:11:33 AM(UTC)
cvex4370B Jenn Air Grill element does not heat up (Oven Repair (including Ranges and Cooktops))
by Guest 4/13/2021 8:44:32 AM(UTC)
