Mike Bart.
#1 Posted : Thursday, November 12, 2015 7:02:08 PM(UTC)
Mike Bart.
Just resealed and put new slides in the dryer to have it burn the wires off of the heating element. repaired the wires and it did it again. Checked the thermistor and it ranges from 15Kohms to 2Kohms when heated. Both the high limit and cycling thermostat will open with the use of a lighter. The cycling thermostat took about 15 seconds and the high limit switch took about 30 seconds of blue flame on the sensor with a normal lighter to open the contacts. The only heat damage is at the ends of the wires connected to the heater elements, there are no signs of over current anywhere in the dryer. Before I replace the thermistor, thermal fuse (I think it should have opened), cycling thermostat and the high limit switch, I wanted to ask this forum for their experience and opinion on why the heating element is likely not cycling and the safeties apparently not working properly.
The dryer has been fully disassembled and cleaned.
Your help and input is appreciated
Thank you in advance,
Mike
#2 Posted : Friday, November 13, 2015 1:19:34 AM(UTC)
Parts for Amana NDE8805AYW Dryer - AppliancePartsPros.com
See the attachmenhttp://forum.appliancepa...icons/editor/attach.gift for the wiring diagram.
Unplug the unit and both wires at the heating element.
Measure across the heating element, should be around 8 to 12 ohms.
If OK then measure from each side of the element to it's case, both should be infinite ohms.
If not the heater is grounded and should be replaced.
If the above is OK.
Undo the wires for the heater at the control board and measure across the heater relay contacts, should be infinite ohms. If not the heater relay contacts are welded together.
Mike Bart.
#3 Posted : Saturday, November 14, 2015 9:11:55 AM(UTC)
Mike Bart.
Denman,
Thanks for the good diagram and troubleshooting aids.
The element measures in at 10 ohms and is open to ground, while the control relay is open, without power applied to the closing coil.
The thermistor measures 11.25 Kohms at room temp (70 degrees) and at body temp measures 6.7 Kohms after about 5 minutes of contact, and was still slowly dropping in resistance.
Am I right in thinking thermistor is the sensor used to control the heater relay?
Ran the diags from the procedures you gave and got two codes, 1. Heater on and drum temp not increasing. 2. Selected dryer temp not reached.
#4 Posted : Saturday, November 14, 2015 10:22:19 AM(UTC)
[COLOR="Blue"]Am I right in thinking thermistor is the sensor used to control the heater relay?[/COLOR]
Yes.
It looks likethe control board is not sensing the change in temperature.
Check the tracks and connection where the thermistor attaches to the board.
if they are OK then it is probably a bad board.
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
Kenmore Dryer Overheating and weak (Dryer Repair)
by Cardiaccat 9/3/2017 9:25:50 AM(UTC)
Dryer Overheating When Not Running (Dryer Repair)
by Chris McCain 4/5/2017 8:06:45 AM(UTC)
Maytag Dryer Overheating (Dryer Repair)
by atem2144 10/28/2016 12:34:41 PM(UTC)
dryer overheating (Dryer Repair)
by dave3712 10/15/2016 8:16:37 AM(UTC)
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Whirlpool Duet electric dryer overheats despite replacing various parts (Dryer Repair)
by Manec 8/18/2016 6:49:44 PM(UTC)
Kenmore Dryer Overheating (Dryer Repair)
by atem2144 8/17/2016 1:41:31 PM(UTC)
Whirlpool Dryer Overheat. Lots of diagnostics and parts replaced (Dryer Repair)
by Mike6158 7/1/2016 4:00:23 PM(UTC)
by dadunn60 3/1/2016 9:43:04 AM(UTC)
dryer overheats/shuts off (Dryer Repair)
by texasoutcast 6/24/2015 7:01:12 PM(UTC)
by sfhutchi 2/28/2015 1:57:08 PM(UTC)
Electric Dryer overheats and blow thermal fuses (Dryer Repair)
by hall9107 1/29/2015 10:04:39 AM(UTC)
