donnahi5
#1 Posted : Sunday, September 27, 2015 6:13:22 AM(UTC)
donnahi5
the front left burner is stuck in high even though the dial is set on low
#2 Posted : Sunday, September 27, 2015 7:49:05 AM(UTC)
Here are your parts.
Parts for GR44LXMC - AppliancePartsPros.com
Choose the correct unit from the Matching Model Numbers section.
I would replace the infinite switch that controls that burner.
Burner Problems for Kenmore 790.99123404 Range (Oven Repair (including Ranges and Cooktops))
by whitedavidp1 1/17/2020 12:51:57 PM(UTC)
Whirlpool stove burner problem (Oven Repair (including Ranges and Cooktops))
by Cardiaccat 2/24/2019 5:22:18 PM(UTC)
Viking Gas Range Burner Problem (Oven Repair (including Ranges and Cooktops))
by pd78 1/23/2019 4:12:13 AM(UTC)
Wolf SB486 Burner Problem/Adjustment (Oven Repair (including Ranges and Cooktops))
by HRMCHAN 9/6/2016 6:51:06 AM(UTC)
One burner problem: on-off-or full heat; nothing else (Oven Repair (including Ranges and Cooktops))
by efahrens 7/20/2015 7:29:12 AM(UTC)
Burner problem with Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by philw007 1/20/2015 8:35:01 AM(UTC)
GE Burner Problem (Oven Repair (including Ranges and Cooktops))
by HkyFrk 4/3/2012 6:56:33 AM(UTC)
Americana Burner Problem (Oven Repair (including Ranges and Cooktops))
by Ken King 2/9/2012 9:21:08 AM(UTC)
Off & on Burner Problem (Dryer Repair)
by Nancy McMullen 12/27/2011 9:03:37 PM(UTC)
Burner problem (Oven Repair (including Ranges and Cooktops))
by rnhamski 10/7/2011 5:01:44 AM(UTC)
oven burner problem (Oven Repair (including Ranges and Cooktops))
by richtfan 4/26/2011 2:00:03 PM(UTC)
by twarshavsky 10/4/2010 7:48:14 AM(UTC)
kitchen aid cooktop dual burner problem (Oven Repair (including Ranges and Cooktops))
by danjoc 4/12/2010 5:53:13 PM(UTC)
by jstaples 3/20/2010 11:08:13 AM(UTC)
kitchenaid kgrt500bal2 front burner problem (Oven Repair (including Ranges and Cooktops))
by hgminnesota 10/2/2009 3:32:17 PM(UTC)
