DIYChallenged
#1 Posted : 10 years ago
DIYChallenged
Our He LG clothes washer has started leaking whenever we do a load of wash. We have checked the drain, which is NOT clogged with lint or anything else.
Has anyone else encountered this problem? If so, is there an economical DIY solution? And how does one do this?
It's an LG TROMM WM2277HW washer between 5 and 10 years old.
THANKS!
sidfink43
#2 Posted : 10 years ago
sidfink43
Operate the machine with the bottom panel off and see if you can locate the source of the leak. Most of the time it would involve the rubber gasket around the opening, but check the drain hoses from the tub also.
Washer leaks at end of cycle only (Washer Repair)
by Orvilejulius 2 years ago
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 3 years ago
Washer leaks water only when using water outside (Washer Repair)
by MattWasPele 5 years ago
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 5 years ago
GE Washer leaks after sitting? (Washer Repair)
by redjada 7 years ago
Washer leaks on front door (Washer Repair)
by robertkral1 8 years ago
Washer leaks and fills drain tray (Washer Repair)
by boberp 9 years ago
Kitchenaid Dishwasher Leaks at Float (Dishwasher Repair)
by macd2x 9 years ago
Dishwasher leaks front door (Dishwasher Repair)
by kbratto 10 years ago
New Maytag top load Washer Leaks in Front (Washer Repair)
by Gadgetmonster 10 years ago
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 10 years ago
Kenmore portable washer leaks (Washer Repair)
by Jimisand 10 years ago
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 10 years ago
Washer Leaks while filling up .. Large Loads Only (Washer Repair)
by martynva 11 years ago
Amana Washer Leaks (Washer Repair)
by axis9313 11 years ago
