DIYChallenged
#1 Posted : Monday, September 14, 2015 10:15:27 AM(UTC)
DIYChallenged
Our He LG clothes washer has started leaking whenever we do a load of wash. We have checked the drain, which is NOT clogged with lint or anything else.
Has anyone else encountered this problem? If so, is there an economical DIY solution? And how does one do this?
It's an LG TROMM WM2277HW washer between 5 and 10 years old.
THANKS!
sidfink43
#2 Posted : Tuesday, September 15, 2015 5:37:39 PM(UTC)
sidfink43
Operate the machine with the bottom panel off and see if you can locate the source of the leak. Most of the time it would involve the rubber gasket around the opening, but check the drain hoses from the tub also.
Washer leaks at end of cycle only (Washer Repair)
by Orvilejulius 8/13/2023 8:42:38 PM(UTC)
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
Washer leaks water only when using water outside (Washer Repair)
by MattWasPele 9/21/2020 9:46:26 AM(UTC)
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 8/1/2020 8:44:37 AM(UTC)
GE Washer leaks after sitting? (Washer Repair)
by redjada 4/11/2018 2:46:00 PM(UTC)
Washer leaks on front door (Washer Repair)
by robertkral1 10/4/2017 11:41:47 AM(UTC)
Washer leaks and fills drain tray (Washer Repair)
by boberp 3/13/2016 7:27:42 AM(UTC)
Kitchenaid Dishwasher Leaks at Float (Dishwasher Repair)
by macd2x 11/8/2015 7:29:26 AM(UTC)
Dishwasher leaks front door (Dishwasher Repair)
by kbratto 8/26/2015 9:53:11 AM(UTC)
New Maytag top load Washer Leaks in Front (Washer Repair)
by Gadgetmonster 7/10/2015 9:11:53 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Kenmore portable washer leaks (Washer Repair)
by Jimisand 3/9/2015 10:38:25 AM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Washer Leaks while filling up .. Large Loads Only (Washer Repair)
by martynva 7/26/2014 3:17:06 AM(UTC)
Amana Washer Leaks (Washer Repair)
by axis9313 6/24/2014 3:50:30 PM(UTC)
