jaybick
#1 Posted : 10 years ago
jaybick
Our dryer runs then shuts off after 10 mins? I have replaced the cycling thermostat, what else could be the problem?
#2 Posted : 10 years ago
http://www.appliancepartspros.c....aspx?model=DBSR453EB2WW
By shut off I am assuming you mean that the motor stops.
Can you restart it right away or do you have to wait several minutes?
If you have to wait then it is probably the motor overheating.
The motor's thermal protect is opening and you have to wait for the motor to cool down so it resets.
Could be:
That the motor is clogged with lint and not cooling.
That there is too much drag on the motor. Try turning it in the correct direction manually. It should turn fairly easily. You may want to try this on a couple other units to get a feel for it. If there is too much drag it could be either the rear or the front drum bearings.
That the motor is on it's last legs.
Dryer Repair Again and Again (Dryer Repair)
by Guest 3 years ago
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 3 years ago
Dryer repairs (Dryer Repair)
by P3FE 3 years ago
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 5 years ago
Dryer Repair Issue (Dryer Repair)
by jdharrin 6 years ago
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 7 years ago
Dryer repair Help! (Dryer Repair)
by Hah45 8 years ago
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 9 years ago
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 9 years ago
Dryer Repair (Dryer Repair)
by sotomargie 9 years ago
Dryer repair (Dryer Repair)
by dchurch 10 years ago
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10 years ago
by Tom Campion 11 years ago
by kencorey281@gmail.com 11 years ago
by fredpeterson543 12 years ago
