dryerman101
#1 Posted : Sunday, August 16, 2015 7:15:12 PM(UTC)
dryerman101
Ice maker not making cubes,I put in a new filter when the problem first happened and that solved the problem, but about 1 month later no ice at all.
CletusT
#2 Posted : Monday, August 17, 2015 4:26:29 PM(UTC)
CletusT
Is the fill valve cycling on to allow it to fill the ice maker? Sometimes the tube leading into the ice maker mold where the water comes in will develope an ice blockage which prevents the mold from filling.
Is the ice maker cycling through it's normal cycles, bale arm raising and lowering?
dryerman101
#3 Posted : Tuesday, August 18, 2015 7:04:09 AM(UTC)
dryerman101
I do not hear the ice maker cycling , how would I check for an ice blockage?
CletusT
#4 Posted : Tuesday, August 18, 2015 7:07:57 AM(UTC)
CletusT
Just get to where you can see the tube leading into the ice maker and see if it is blocked with ice.
There may be problems inside the ice maker if the water fill valve is cycling when the tray empties.
dryerman101
#5 Posted : Tuesday, August 18, 2015 4:21:22 PM(UTC)
dryerman101
I checked and did not notice it cycling,so I removed the unit and noticed ice cubes in the unit but were not ejected,by there being ice in the unit I would say there is no ice blockage.
CletusT
#6 Posted : Tuesday, August 18, 2015 4:58:05 PM(UTC)
CletusT
Yes as long as there is no ice visible where it comes in. The next thing I would think would be the thermostat inside the ice maker. Many times, it is more cost effective to replace the entire ice maker than to replace parts inside it. I would check prices on a replacement unit as well.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
