Ray F
#1 Posted : Monday, August 10, 2015 6:13:40 PM(UTC)
Ray F
The unit stopped working after filling. Timer appears to have plastic dust and does not feel like it is turning and clicking as usual. I am having trouble accessing removing ends on upright panel. I know that I need to unscrew the upright after removing the ends.
fairbank56
#2 Posted : Tuesday, August 11, 2015 5:23:35 AM(UTC)
fairbank56
Groups: Expert
You don't need to remove the ends of the panel to open it. There are two spring clips under the panel, one at each end. Use a putty knife and slide under the clips to release them and then rotate the panel back. Problem is likely the lid switch. Check for loose screws on the left side lid hinge. This hinge activates the hidden lid switch. Lid must be closed for washer motor and timer to operate.
Eric
Auto-dry setting timer does not advance (Dryer Repair)
by herseywa 6/16/2020 11:35:45 AM(UTC)
Whirlpool (Roper) electric dryer runs and heats. Timer does not advance in auto or ti (Dryer Repair)
by biomed172 10/10/2014 6:12:03 PM(UTC)
No Heat, Timer Does Not Advance (Dryer Repair)
by MRGETITFIXED 8/27/2014 8:36:01 AM(UTC)
washer tub full spins but water still in timer does not advance (Washer Repair)
by scooty1 3/10/2013 6:55:34 AM(UTC)
Amana Dryer Timer Does Not Advance in Auto Mode (Dryer Repair)
by splehigh 3/5/2013 6:15:29 PM(UTC)
Whirlpool Dryer - No heat, Timer Does Not Advance (Dryer Repair)
by katielove22 10/21/2012 12:26:02 PM(UTC)
NO Heat - Timer does not advance (Dryer Repair)
by JMWITT 3/18/2012 6:08:06 PM(UTC)
Electric Dryer Not Producing Heat & Timer Does Not Advance in Auto Dry Settings (Dryer Repair)
by hifroggyjenn 1/12/2012 10:26:47 AM(UTC)
Maytag gas dryer. Timer does not advance and does not heat. (Dryer Repair)
by lfregia 11/27/2010 9:18:06 AM(UTC)
maytag dryer timer does not advance (Dryer Repair)
by Carbon 7/23/2010 3:33:04 PM(UTC)
Timer does not advance dryer runs no heat (Dryer Repair)
by Rmelc1 7/20/2009 1:25:42 PM(UTC)
Timer does not advance in auto mode (Dryer Repair)
by rman 6/27/2009 11:10:43 AM(UTC)
Timer does not advance in auto dry mode (Dryer Repair)
by Teager 6/16/2009 1:56:42 PM(UTC)
Amana Dryer dries slowly, and More/Less Dry Timer does not advance (Dryer Repair)
by dtshenoy 4/13/2009 6:24:55 AM(UTC)
Timer does not advance (Washer Repair)
by Lloyd Kneller 9/25/2007 1:03:54 PM(UTC)
